Smart Irrigation System automatically detect the soil moister via soil moisture sensor. Based on the soil moisture value the microprocessor give command. If the soil moisture value is less than the threshold value set by the user then the microprocessor will turn on the pump(water motor)automatically.If the soil moisture value is greater than the threshold value then the microprocessor will turn off the pump(water motor)automatically. And send information about the pump and the moisture percentage to user via sms and also send data on website so that user can see the values and also get all the detail of the system like(motor info, moisture percentage etc)in table format. you can the examples of the data received at website the website.Given address: https://jjiot1.000webhostapp.com
