The first image indicate the finished music player. In the frond side there are two speakers and one small push switch to move to the next song and one small SMD preset resistor for controlling the music volume. In the bottom side there is the SD card port, headphone port and a mini USB port for charging the in-built battery(Li-ion cell). In the top white top side there is 3 LEDs Which are used to work as an emergency light system. The music player and the light are controlled by using the SMD slide switch which is placed at the side.
The ATtiny 85 is the brain of the circuit it decode the files from the SD card and it generate the audio. The power amplifier LM386 drive the speakers.
For more about the circuit details, visit my BLOG,https://0creativeengineering0.blogspot.com/2019/06/diy-portable-pocket-music-player-using.html
The program is not made by me. So for details about the Program, visit the given link,
http://elm-chan.org/works/sd8p/report.html
For more projects visit my YouTube , Blog, Instructable pages.
Discrete Electronics Guy
Augusto
Lincoln Uehara
serdef
schwarzrmsu
