Not done yet but here are the changes I made today...
ardublock.xml:
-- genus-name changed for status BlockConnector so that the dropdown will eventually show PRESSED/NOT PRESSED
-- These two BlockGenus objects need to be changed to create two new buttons called PRESSED and NOTPRESSED including changes to block-mapping.properties/ardublock.properties/new java files.
-- BlockFamilies create menus for dropdown options
-- I added two new properties for the BlockGenus
At the end of the day I ended up with this error:
I might have deleted the BlockGenus.class file from openfiles, so I need to figure that out...😬
