Powering uRAD Monitors via PoE
A project log for Global radiation monitoring network
The uRADMonitor is a plug-and-play, low power, self contained radiation monitoring device, connected to a centralised server component.
radu-motisanRadu Motisan 12/02/2014 at 23:100 Comments
Jeff wrote a comprehensive guide on how to add POE to uRADMonitor devices http://www.uradmonitor.com/powering-urad-monitors-via-poe/
20141129_235246
When I received my URAD Monitor, I was trying to think of the best placement where it would satisfy the requirement to be outdoors but still remain close to a power source. Having worked with PoE WiFi devices before, I contacted Radu to mention a PoE solution I was considering. Since I was able to successfully power my uRAD Monitor via PoE, I documented how I was able to achieve this in hopes it can be of use to others who may be interested in using PoE.
10/100 Ethernet can run off of just 2 pair (four conductors), which leaves the other 2 pair unused. Passive PoE leverages the unused pairs and sends power over them.
First, keep in mind that there will be some loss of voltage as you add distance. Assuming 24AWG Ethernet, using 4 conductors (2 pair) for power, a current draw of .160A, and a distance of 10 Meters, the loss should only be about .13 Volts. There are calculators online to help you determine the loss (which is how I came up with this value). Since we are working with less voltage than is typically found in PoE, the voltage drop percentage will be more severe per meter since lower voltages are more greatly affected by the resistance in lengths of wire.
The uRADMonitor uses 2.1mm DC Barrel Jacks (which are common) and you should be able to use "Passive PoE Injector Cables", like the cable sold by SparkFun: http://www.adafruit.com/product/435 (as an example). However, I opted to purchase DC Barrel Jacks with Screw Terminals (which you can find for a few dollars on ebay). However you decide to use PoE, use a multimeter to make sure that the polarity of the barrel jack is not being swapped, and that power is not inadvertently being sent through the cat5 connector which may damage your device. Avoid using connectors/adapters that are not designed to be used together as they may be built differently or utilize different pairs. Don't use a standard PoE power supply as it may be designed to send 12, 24, or 48 volts.
Since the cable will be partly outdoors, it is ideal to use outdoor UV Stabilized Ethernet cable (I happened to have Ubiquity TouchCable on hand). Strip a generous amount of cabling because you will have to start over is your Blue/Brown pairs are too short.
20141130_12512420141130_125456
Terminate the end per the T568B wiring order, but only using the Orange and Green pairs:
Pin1: White/Orange
Pin2: Orange
Pin3: White/Green
Pin6: Green
Pins 4/5/7/8 will be empty in the RJ45 connector. The Blue and Brown pairs should be stripped at the end and twisted together. Optionally you can use a small amount of solder to fuse them together, but don't use too much or they may not fit into the DC connectors.
20141130_125915
I used the Brown pair (normally pins 7/8) to carry Negative, and the Blue pair (normally pins 4/5) to carry Positive. This is in line with the IEEE 802.3af using spare pairs standard. Insert the stripped wires into the connectors and tighten them down firmly. You will do the same thing at both ends, using a male DC jack on one the uRADMonitor end of the cable, and a female DC jack on the network end. You should end up with something like this:
(Don't forget the cable is easier to feed through holes BEFORE you terminate it, as I forgot!)20141130_001251
Verify the polarity on the uRAD end remains correct after traveling through your cable by using a multimeter. On the device side, I had barely enough cable length to be able to reach the DC port. On the indoor side, I used the included USB to DC Barrel Jack cable that came with my device to connect my terminated cable to a power source. The router I use happens to have have a powered USB port which I was able to use to power my uRADMonitor.
20141129_23524620141130_152232
I opted to add a little hot glue to the back of the connectors to keep moisture out.
20141130_152009
