Reduced Battery Capacity Due to Size
A project log for Booze
Booze is a tiny beacon similar to tile in concept but the firmware is customizable and has a rechargeable lipo battery(60mAH).
boozebooze 06/27/2019 at 10:000 Comments
I will be reducing the battery capacity to 60mAH from 75mAH because or the size. The 60mAH battery with dimensions 3mmx10mmx25mm will allow more components to be squeezed into the pcb.
