Wow! The project won the best documentation prize for the Connected World Contest!
Things have been a bit busy, so no experimentation has been allowed on the LCD at this stage, but I hope to have working hardware sources soon.
While this project has set out to offer a solution for the LCD display, the oven itself has met a different fate. It was decided to modify the hardware completely and give it a more useful set of features. You can see the work on this over here - https://hackaday.io/project/167324-brtro-420-better-blazin-mod
![](https://cdn.hackaday.io/images/4345421570033590665.jpg)
This new project is using the SAMC21 5V tolerant ARM MCU as well, so the working getting Arduino up and running on that will feed back into this project.
