Mysterious wrong result for circuit with inductor?
A project log for How to handle ADALM2000?
ADALM2000 by Analog Devices is quite multi-function device but I could not find "how-to" for my specific application. So I will show how!
kodera2tkodera2t 07/05/2019 at 06:260 Comments
And let's measure 455 kHz IFT frequency response....
We can see "shape" of response, but the issue is amplitude value. If I found just inductor can provide 40dB gain, I will get Nobel prize (or Edison medal?) As you see, the shape is correct, and it seems it has a resonant frequency of 439 kHz but its absolute value of amplitude is not reliable at all. This is not connection issue but may be impedance mismatch or,,,, transmission evaluation is made just by voltage, and multiplied voltage by IFT may producing miracle 40 dB.
