Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
Industrial Interface for Arduino
Safely connect your micro controller to industrial sensors up to 30 VDC
Harris NewstederHarris Newsteder
Following Follow project
Liked Like project
Become a Hackaday.io member
Not a member? You should Sign Up.
Already have an account? Log In.
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
Public Chat
3 comments
5 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 3
View Gallery
Public Chat
594
3
5
2
Team (1)
  • Harris NewstederHarris Newsteder
Join this project's team
  • P1-000 GitHub Page
ongoing project
hardware
arduino industrial sensor automation configurable industry interface microcontroller
This project was created on 07/10/2019 and last updated 2 years ago.
Description
Hi, I'm Harris Newsteder.
I developed this sensor interface board during my ongoing effort to create a really great open source PLC.
It's an 8 channel interface board that allows you to use industrial sensors with your Arduino or other 5V microcontroller. You can use both NPN (sinking) and PNP (sourcing) sensors from 5 to 30VDC.
You can configure each channel to interface with either one of the 2 sensor types. That means you can use any combination of 8 NPN or PNP sensors on any channel you'd like and then reconfigure it on the fly if you need to.
You can use multiple sensors of different voltages at the same time (as long as they have a common ground), such as a 5V, a 12V, and a 24V sensor.
The board electrically isolates your microcontroller from your sensors up to 1kVDC, and has 8 red LEDs to indicate the status of each channel (on / off).
Its design is completely open source and you can find all the project files on GitHub.
Details
Log In/Sign up to comment
Sign up with Github
OR
rvalente wrote 07/16/2019 at 01:39 • point
Hi,
thanks by sharing your schematics.
You toke a different approach for the input protection. What  I'm used to see in plcs  PNP/NPN inputs for PLC is a voltage divider, where the lower resistor is in parallel to the optocouple led them, the phototransistor is voltage compared and the signal goes to the mcu. This is a very simple, reliable and cheap method to protect the inputs.
What I would do for a large voltage range (but not NPN/PNP compatibility, since I do not care about NPN input, since in america/europe continents we almost only use PNP anyway) would make a constant current source for each input, them feed the optocoupler.
What you did (voltage divider them compare them optocoupler) was the first time I've ever seen and I curious why you took this approach.
Greetings, Renan
rvalente wrote 07/14/2019 at 14:03 • point
Hi, looks very promising!
I've a some experience with PLCs and developing some custom boards for industrial specific tasks.
I wish I could see more of the schematicsm, how you managed the ios.
Greetings from Brazil
Harris Newsteder wrote 07/15/2019 at 23:52 • point
Hey, just made the GitHub page public. It has all the KiCad design files and a full schematic in the doc folder. Check it out and if you have any more questions just let me know.
A transformer-like bar build from an old piano with original keyboard and hammer mechanics used as MIDI controller
Project Owner Contributor
MIDI piano bar
vch1vch1
How a Soft Condensed Matter Sensor (SCMS), combined with Soft Body Dynamics (SBD), ESP2866 and node.js enabled a gesture controlled drone
Flying a parrot drone with a wearable sensor
Markus LeutwylerMarkus Leutwyler
This page is a collection of tech that was developed during pneumatic projects and deserve a write-up of their own.
Pneumatic Tech for Prototyping
Nelson PhillipsNelson Phillips
Have you ever wanted to connect lego sensors to Arduino? Now you can any sensor to any microcontroller using my Lego sensor adapter board.
Use Lego EV3 sensors with Arduino
StanislavJochmanStanislavJochman
Going up?
© 2021 Hackaday
Yes, delete it Cancel
You are about to report the project "Industrial Interface for Arduino", please tell us the reason.
Send message
Remove Member
