Considerations for Switch Components and Tubing
A project log for Read Rope / Electronic Nerve
This is an open-source hardware project for a device that outputs a certain voltage depending on where the rope/wire is bent.
pablo-antonio-camacho-jrPablo Antonio Camacho Jr. 07/30/2019 at 21:010 Comments
I managed to solder together SMT tactile switches in parallel with resistors.
Unfortunately, a solder joint breaks when trying to push the read rope into 0.170 inch inside diameter vinyl tubing.
From this experience, I have learned more considerations to make to turn this into a final product.
Switch
Tubing
Flexible PCB
