'ETHERNET COMMUNICATION'
A project log for 'Thor' robot with addons and GUI
Thor robot based on the author AngelLM
dannyvandenheuveldannyvandenheuvel 01/07/2017 at 18:543 Comments
Ethernet communication with ultratronics board!
Now I can command 'Thor robot' from TCP client
Olaf Baeyens wrote 01/07/2017 at 21:04 point
It runs softer than last time.
dannyvandenheuvel wrote 01/07/2017 at 21:22 point
Everything has been optimized, I'm working on the gamepad integration. After that I'm going to make a little pcb in the middle of the base to bring all connections to there. From that position I can plug in every wire that Is needed to complete the robot.
I'm not happy with all the wires hanging there.
Olaf Baeyens wrote 01/07/2017 at 21:31 point
You are unstoppable! :-)
