New revision
A project log for ESP32 WiFi Game
This is game device is inspired by SpyTag WiFi game.
Miroslav ZuzelkaMiroslav Zuzelka 07/21/2019 at 18:330 Comments
After I tested all parts of the board, I made necessary repairs to the design. I also moved a bit LCD forward to antenna of the ESP32 so it would not collude with joystick for 5-way switch,
New design looks like this:
No major changes so it looks like older revision.
I ordered boards at ALLPCB with some other boards and and again about week, I had them home.
I assembled one, tested uploading of the firmware, LED´s & 5-way switch and everything works as it should. I was planning to use pogopins between LCD and baord but I have just 16 mm long ones and those are almost 3 times longer than I need so I designed spacer underneath LCD and this one will sit on top of the ESP32 and will not be easily detachable.
Here you can see board with and withou LCD:
