Buttons
A project log for Solder paste and flux dispenser
DIY for hobby use
vitalyVitaly 08/07/2019 at 03:550 Comments
For dispenser it's important to have soft control button. Because if you need to apply big force, needle may shift out of small pad. There 2 main parameters:
Human skin is "soft". To be convenient, button should have big height or big square. To be sure, buttons with low operational force, available at LCSC, were tested:
The most promising are:
EVQQ2B03W looks preferable - more compact.
