PCB v3
A project log for Solder paste and flux dispenser
DIY for hobby use
VitalyVitaly 11/28/2019 at 22:462 Comments
Assembled third version of PCB:
My friend, second author of our sensor-less speed control for grinder decided to join this project too. He will help with drivers debug (current firmware runs in simulator only). And i will continue with reflow micro table for this time.
Sorry for slow updates - that's specific of OSS development. Instead of doing single project, i prefer to do multiple things in parallel. This allows to share efforts, and each can pick preferable parts where he is most qualified.
jonathanleichner wrote 01/08/2020 at 14:51 point
Good Day
How is progress going on this project, love the look of this. Very keen to put one together. I have just received the motor.
Wanting to know if you have had any other issues with the board before i order a board.
Thanks, great work.
Vitaly wrote 01/08/2020 at 16:46 point
Hi! Development process is open, you can see every change on github. At current moment indicator/joystick/usb are alive, i will post new log record soon. Motor bridges and current sensor not tested yet.
If you are going to develop - PCB is ok. In other case i'd suggest to wait for sure.
