Macrorig controlled from app
A project log for PiXPi dslr camera controller
Modular and programmable DSLR camera trigger
krzysztof-krzeslakkrzysztof krzeslak 08/20/2019 at 19:410 Comments
Hello
As i wrote in previous update lately I was working on adding possibility to control macrorig/stepper driver from android app, and just wanted to share some effects of it:
 Generally it works, it's simple and there are some fine tweaks still needed, but it will come in future, what was currently added on app side is:
Added "step" mode in ports configuration screen:
                                                          "Step" mode can be set on each port
            After setting port into "step" mode following block will become available:
With these block you can move steppers forward and backward and set desired travel, currently smallest possible move for macrorig is 0,005mm(1 step).
