Infinity Gauntlet Controlled Home Automation
I control appliances when I move this Infinity Gauntlet
I made a home automation system using cardboard infinity gauntlet. For making Infinity Gauntlet Controlled Home Automation, I used Arduino unos, An Arduino nano, Servo motors,Led strip, and NRF24L01+ 2.4GHz Wireless RF Transceiver Modules to communicate between two Arduino boards wirelessly.
Hardware and Materials Required
Arduino Mega + USB Cable II Arduino Uno : https://amzn.to/2qU18sO II https://amzn.to/2qU18sO Arduino nano: https://amzn.to/2zMXJU8
9v battery: https://amzn.to/2zIcBmL
AA battery: https://amzn.to/2utifnx
Resin : https://amzn.to/2JX9RDD
Switch: https://amzn.to/2zIcBmL
Jumper wires: https://amzn.to/2zIcBmL
Male DC Barrel Jack Adapter for Arduino : https://amzn.to/2zIcBmL
Micro Servo 9g : https://amzn.to/2zIcBmL
Mini Breadboard : https://amzn.to/2zIcBmL
9v Battery Clip Connector : https://amzn.to/2zIcBmL
Cardboard : https://amzn.to/2zIcBmL
Ruby : https://amzn.to/2zIcBmL
NRF24L01+ 2.4GHz Wireless RF Transceiver Module: https://amzn.to/2zIcBmL
MPU 6050 : https://amzn.to/2zIcBmL
LED Strips : https://amzn.to/2zIcBmL
Receiver6_Clock.ino
ino - 1.11 kB - 07/29/2019 at 03:39
Download
Receiver5_ac_portable.ino
ino - 1.19 kB - 07/29/2019 at 03:39
Download
Receiver4_Lock_Door.ino
ino - 1.11 kB - 07/29/2019 at 03:38
Download
Receiver3_Lamp_Switch_.ino
ino - 1.17 kB - 07/29/2019 at 03:38
Download
Receiver2_Air_Purifier.ino
ino - 1.21 kB - 07/29/2019 at 03:38
Download
View all 7 files
  • 1
    Making the Infinity Stones and the Infinity Gauntlet From Cardboard
    For making infinity stones, I used ruby, epoxy resin + Hardener, colour paint, and clay (you can use silicon). - Push ruby into the clay and pull it out.
    - Mix the resin, hardener, colour paint and divide it into six different cups, one for each color.
    - Pour the epoxy into the mold and Let it dry.
    You can watch this video , if you want to know how I made infinity gauntlet from cardboard.
  • 2
    Arduino Wireless Network With Multiple NRF24L01 Modules
    A single NRF24L01 module can actively listen up to 6 other modules at the same time. You can define the addresses of the nodes in octal format. In this project, the address of the base (Infinity Gauntlet) is 00, the base children addresses are 01 to 0. So from the base (Infinity Gauntlet) , using a MPU6050 we will control the servo motor at the node 01 – 0.
  • 3
    Wiring Diagram for Infinity Gauntlet
View all 5 instructions
