After making the changes discussed in the previous posts, I tested the precision by measuring the same oil (Extra Virgin Sample 1) 3 times. Here is the result:
![](https://cdn.hackaday.io/images/1520331567269622660.png)
I also re-tested the different oils. I'm surprised (and concerned?) by how little absorbance was detected in the canola and light samples. But in general I think the results are decent.
![](https://cdn.hackaday.io/images/6229431567269680581.png)
Lastly, here is an updated illustration of the spectrum-finding GUI. The previous version shows inadequately collimated light; the issue is visible in the middle of the spectrum. This version doesn't seem to have that issue.
![](https://cdn.hackaday.io/images/7695921567269959152.png)
