Regular 8 software now available
A project log for 8mm Film Scanner
Scan regular 8 and super 8 film and create a digital copy
antonAnton 03/20/2022 at 12:160 Comments
I added a version for regular 8. Don't forget to use the correct sprocket!
Also - for R8 and S8 you need to adjust the crop settings (line 20 onwards). This is necessary, because your camera / lens setup will most likely be different to mine.
