new core unit to test
A project log for 8mm Film Scanner
Scan regular 8 and super 8 film and create a digital copy
antonAnton 05/03/2022 at 08:220 Comments
If you want to test the new core unit from the V2 scanner on the V1 scanner - you can do so:
https://hackaday.io/project/185040-8mm-film-scanner-v2/log/205805-stl-files-for-new-core-unit
