I was able to verify few operations on basic arguments and compare them to real Sinclair Scientific for match. Following problems remain:
- LED blurs at higher frequency. Calculation can be done at 12.5MHz but LED is blurry above 40kHz or so
- breakpoint and single step logic needs to be laid out more logically on the switches, and dual clock unit avoided
- VGA tracer still drops some character from display.
Note that none of the above impacts calculation. I also briefly tested TI mode, seems no regression was introduced there.
zpekic
