STM8S001J3RS485 MODBUS Sensor Board V1.1
A project log for MODBUS Things with STM8 eForth
Projects (and mishaps) for talking MODBUS to STM8 eForth (or not)
ThomasThomas 10/13/2019 at 19:510 Comments
When doing hand soldering I learned "first hand" that the orientation of 0603 components matters, and consequently I worked a bit on the component placement of the tiny STM8S001J3RS485 PCB. Using 8 mil signal track width, 6 mil clearance and 10 mil via drills made it a lot easier compared to sticking with the KiCad defaults. The power supply now forms a rail from left to right, switching the side of the PCB about in he middle.
The text on the silcscreen is friendlier, too (even if they make good use of the 400DPI silcscreen that @oshpark provides (i.e. the print is tiny):
The 0603 components on the back side now are also easier to populate.
The new board is available on the @oshpark shared project pages, and the GitHub repo has been updated.
