v2.0, Button and Octoprint, coming
A project log for PrintEye
A lightweight ATMega328p based information display panel thingie for RepRap firmware based 3D Printers; specifically the Duet controller.
owenOwen 11/23/2019 at 13:320 Comments
I've finished work on a v2.0-dev branch to add more button functions, resets and sending OctoPrint action commands for pause/resume. Plus changes to how the arbitrary text system works. Hopefully I can get progress monitoring from OctoPrint working too.
I even reduced code size and memory use 👍
It builds, but is completely untested.. I'll test it soon and publish once I have worked the OctoPrint setup out..
