Victory! Custom code on a Chitu board
A project log for Chitu 3D Printer Mainboard Hacking
Studying the encryption on Chitu's 3D Print controllers
jc-nelsonJ.C. Nelson 09/24/2019 at 19:451 Comment
The picture is not all that awesome. It's the obligatory "hello" program.
What's cool is that it's running on a Tronxy/Chitu main board with a stock bootloader, meaning that you don't need ST-links, the STM32CubeProgrammer, or anything else to flash it. And if you don't like it, you can always go back.
Patrick Zirker wrote 01/05/2021 at 15:00 point
Amazing work! Nice to see that the base work was done and that it might be an option to change the firmware instead of the whole board. Thanks!
