Gantry and testing
A project log for Open Source Laser Cutter
An open source small(2'X3') and Large (4'X4') laser cutter
sporkiussporkius 09/30/2014 at 01:430 Comments
The rails, gantry, and timing belt have been installed on the laser machine. Thanks to a volunteer (Shawn) we are currently developing a more advanced optics system that allows increased precision and deeper cuts. We are testing CNC functionality using mock Gcode. The small laser cutter also joined our booth at the NYC Makerfaire.
Partially assembled gantry.
X Axis motor with timing gear and ribbon cable for hall effect encoder.
X and Y axis Closeup.
X and Y axis assembled. Ready for timing Belt
Ready for a trip to NYC Makerfaire.
The Router (Bottom right) at the NYC Makerfaire.
