Miscellaneous bits
A project log for OtBC
"Old-timer Board Computer" Mostly because cheap electronics are widely available.
frdric-druppelFrédéric Druppel 09/12/2019 at 22:100 Comments
• I removed all the original wiring harnesses, and just put back the necessary wires to start and run the engine. Here I'm also testing a prototype of a ZVS Flyback ignition coil system (log coming soon) : YouTube link
• First startup sequence test of GPC01 :  Instagram link
