High speed servo control (named 'DPS' Control) Test
A project log for VESCuino Shield Ver 0.1
VESC firmware based Motor Controller; Arduino Shield Type, Stack-able Design and SPI Communication
dongil-choiDongil Choi 10/05/2019 at 14:300 Comments
DPS control allows accurate tracking from very low speed to very high speed. It is a Servo control algorithm that can be applied to VESC firmware as a custom application.
- DPS Control means Degree Per Second Control
- I can command target velocity as DPS unit
- The motor is controlled to track precise position profile to follow the target velocity
