V1 PCB prototype
A project log for ARX Hand Project X1
An advanced low cost 3D printable robotic hand for development in robotics, animatronics and prosthetics
supercellSupercell 11/17/2019 at 13:490 Comments
11 Jan 2019
Two versions of the circuit were created and tested:
- Version 020 which used shift registers for controling the drivers along with a 4 bit R-2R DAC
- Version 010 which used the PCA9685 with a digital potentiometer to control the drivers
Both versions worked well with different benefits. First version was cheaper and the second offered more control via I2C for slight increase in cost.
Eventually, I had decided on using the I2C version for testing and development.
020 PCB Render
010 PCB Render
KiCAD: https://kicad-pcb.org/
