Glasses Frame Designed
A project log for Raspberry Pi AR/Smart Glasses
An experimental pair of discreet Smart glasses
jacob-macleodJacob MacLeod 10/10/2019 at 13:020 Comments
Hi! This is a quick log to say that I have worked out what electronics I want in the glasses, and I have even designed a wireless controller to control the display that will be powered  by an arduino nano, or pro mini. This will then talk to the Raspberry Pi Zero W, which will control the entire thing. I want the Raspberry Pi to be a big factor in the glasses, as it could theoretically replace both desktop PCs and laptops. Because of this, you will be able to plug in an mini HDMI - HDMI adaptor, or use the display connector.
Anyway, that's all for now, so bye!
