Prototyped.
A project log for Aqua328 flexible aquarium controller
A flexible and adaptable controller for Aquariums or other stuff based on the ATMega328P
owenOwen 10/11/2019 at 14:000 Comments
I dont need to prototype most of this, it's pin connections and a mosfet circuit I have used before. But the loudspeaker / buzzer and it's single-transistor amp did deserve a test before I cut a PCB.
This has duely been breadboarded, and works rather well (It's a suggested circuit on a number of electronic design sites). Loud enough to be heard across a shop if needed.
Next step: make the Mk1 board.
