GPIO and the PSoC
A project log for Not Quite Useless Raspberry Pi Replacement
Make a Raspberry Pi replacement using a Cypress Semiconductor Programmable System on a Chip (PSOC 5)
land-boardscomland-boards.com 10/07/2019 at 12:460 Comments
There's an interesting limit on the PSoC for output enables. Each 8-bit port can only have two output enables.
This makes creating a general purpose port difficult. Unless the pin is set to be open collector and driven low. With a pullup on the input. That could work. There would need to be a gate on the output which effectively disables driving the line low.
In order to check the pin assignments,  I created a PSoC design file with all of the ports set up as GPIO lines. As noted above there are only 2 Output enables per block so this did limit the general case of I/O pin direction control on individual pins.
Here's what one 8-bit port looks like:
The Dir_Ctrl register sets the direction of the GPIO pins. The register powers up with all outputs at 0 so this means all of the I/O pins are input pins at power up.
I made ports for all of the pins. This used the following resources:
This is less than half the Control and Status registers in the PSoC. Of course, some of these ports will be set up for specific functions (UARTs, etc).
