More Field Testing
A project log for Bicycle Dashcam
Bicycle Dashcam with License Plate Recognition (ALPR)
richard-audetteRichard Audette 06/24/2020 at 01:380 Comments
On a sunny mid-June Saturday, I took my bike for a ride down Yonge St to lake Ontario with my bicycle dashcam, testing my latest changes (May 18th). Over the course of a 2 hour ride, taking a photo about every 10 seconds:
OpenALPR picked out this dry cleaning sign as license plate 2 H0UR
I’m going to try running these photos through alternate ALPR engines, and compare results. On this run, I tested the Pi Camera V2’s various sensor modes: the streaming modes at 1920×1080 30 fps, 3280×2464 15 fps, 640×922 30 fps, 1640×922 40 fps, 1280×720 41 fps, 1280×720 60 fps, as well as the still mode at 3280×2464. Further testing is likely still required, but I continue to get the best results from the still mode – all of the successful matches were shot using still mode.
Dashcam Successfully Recognizes License Plate
I’m getting better results than I had on previous runs as a result of tweaking the pi-camera-connect NodeJS library to:
However, the images are still not as good as I would like.
Rolling shutter issues are apparent in some photos taken by the Pi Camera V2 while in motion
The Plate Recognizer service has an excellent article on Camera Setup for ALPR. It highlights many of the challenges I’m seeing with my setup:
I might order the latest Pi camera with the zoom lens and see if I get better results.
Reviewing the data from my ride, there’s also an issue with my code that pulls the GPS coordinates from the phone, which I didn’t see when testing at home. I figure this is either the phone locking while I ride, and not running the javascript – I’ll try using the NoSleep.js library before my next test run.
