Setting / viewing the bus
A project log for Nits Processor
8-bit TTL technology processor
cedCed 11/05/2019 at 14:100 Comments
So we've been talking about the bus for some time. But when building a CPU we need two things from the bus:
For this I have built a simple module that manually sets the value of the bus and displays the value of the bus.
However, there are a few contraints to take into account when building such a module:
In the end this module is quite simple with only 2 74HCT245, a bunch of LEDs and resistor networks (it is easyer to use a resistor network than to manually plug 8 resistors).
[Note: do not forget the pull down resistors on the DIP switches otherwise the line would be seen as hanging when the switch is opened]
[note : the NAND gate is used as an inverter, juste because there was one available near the module]
Manual setting of the bus balue:
Displaying the Bus value and bus termination:
Preview of the Breadboard prototype (right of the photo):
