9.7" epaper breakout (Kindle DX screen)
I always wanted a large, affordable E-Ink screen to play around with. The result is a board to talk to a Kindle DX screen with an ESP32.
A breakout board for the ED097OC4 9.7" ePaper (or E-Ink) display. ePaper is a fascinating technology for low-power and pleasant-to-look-at screens. However, ready-made DIY modules for this size and with 4bpp (16 Grayscale) color support are currently quite expensive.
This project uses Kindle DX replacement screens, which are available for 30$ on ebay, making tinkering with those screens much more affordable.
Displayed image By David REVOY - http://durian.blender.org/wp-content/uploads/2009/10/sintel-wallpaper-dragon.jpg, CC BY 3.0, Link
Build it!
KiCad-Project, Gerber files and firmware can be found on github: https://github.com/vroland/ed097oc4-breakout.
Features:
  • 4bpp (16 color) output in ~2 seconds (at 1200x825 resolution)
  • Simple, 2 layer PCB with all components on front
  • Broken out I2C and sensor pins
Thanks to:
Thanks to the work of some awesome people, the hard stuff was already done:
pcb.pdf
A print of the PCB layout.
Adobe Portable Document Format - 168.86 kB - 11/01/2019 at 11:12
Preview
Download
epaper-breakout.pdf
The board schematic.
Adobe Portable Document Format - 84.94 kB - 11/01/2019 at 11:12
Preview
Download
demo.mp4
A short demo video.
MPEG-4 Video - 41.19 MB - 11/01/2019 at 10:27
Download
Gif of the demo video.
Graphics Interchange Format - 9.67 MB - 11/01/2019 at 10:22
Preview
Download
  • Font Rendering and Partial Drawing
    Valentin11/18/2019 at 21:44 0 comments
    Now, finally I implemented what these displays where originally designed for: displaying text. Unfortunately, the ESP32 does not have enough RAM for a real frame buffer (maybe a version 2 will use a module with PSRAM). So, I have to resort to partial refresh / drawing.
    For the image shown above, I first displayed a full-screen grayscale image as usual. Then, I cleared the middle area and proceeded to draw the text line-by-line. If you screen content does not need to be updated often, this should suffice. Otherwise, you can always stream frames via wifi.
    For my tests I used the latin1 character set and the Fira Sans font, however, this is completely customizable.
  • ESP32 timing
    Valentin11/01/2019 at 11:32 0 comments
    Hello World! Finally, the project is ready to go public. If you have any ideas, improvements or comments to share, feel free!
    During the last days, I struggled a bit with getting the timing for the gray scale output right. Each row has to be activated for a only a few microseconds to only dim it slightly. While this worked most of the time, sometimes, the code took much longer, resulting in dark horizontal stripes. Debugging this was quite a journey, since I was new to the ESP32:
    • Coming from the world of Arduino, having a real-time OS running on the chip was new. Disabling interrupts during the critical sections helped, the fact that the noInterrupts() function of the Arduino framework for the ESP32 is just a dummy did not.
    • At this point, most bad stipes where gone, but timing was still somewhat irregular, even when using the hardware timer. I thought using hardware timer interrupts is as good as it gets when trying to do exact timing, but apparently I was wrong. If someone has an idea why this could be, please tell me!
    • Finally, tagging the critical function with IRAM_ATTR and busy waiting for a set number of CPU cycles did the trick.
    Busy waiting does not seem like the most elegant solution, but it works. Refresh times are now at about 2 seconds for a gull grayscale image of 1200x825 pixels. If I could manage to already shift in new data while waiting for the current row to fade, this could be even faster. I'll have to try some things :)
View all 2 project logs
Jürgen Skrotzky wrote 17 hours ago point
Congratulations for this awesome project!
I would like to have something similar - but using the 6" Kindle display - I think it is the ED060SC7.
Is it possible to connect it to your board?
Thx and best regards,
Jorgen
Valentin wrote 15 hours ago point
Hi, glad you like it. Unfortunately, the SC7 uses a different connector than the OC4 (34 vs 33 pin FPC with different pitch). However, as far as I know the driving mechanism for these displays is nearly identical for all models, so you might be able to just swap out the connector. I don't have a SC7 to verify though.
Vadim Radu wrote 01/07/2020 at 13:53 point
Hello,
Congratulations for your project, it's very nice.
I'm working on something similar. Can you share some info regarding the MODE1 and MODE2 pins? what are they used for and why did you tied them to a GPIO?
Regards,
Vadim
Valentin wrote 01/10/2020 at 21:36 point
Hi Vadim,
Sure, but may I known which display you are using? As far as I know, only the ED60SC4-Displays have MODE1 and MODE2 lines. The display I'm using is a 9.7 inch one and has only one MODE line, which is just wired to a GPIO, as drawn on the schematic ;)
