Wiring up
A project log for Fake any display for <50$ and a Raspberry Pi
Fake any display resolution by editing the EDID information stored inside a headless ghost EĀ²PROM HDMI dongle.
steven-rochSteven Roch 11/25/2019 at 20:330 Comments
Use the HDMI breakout beard and plug in the Headless Ghost.
Follow the pinout described in the datasheet of the headless ghost for correct wiring.
Be careful with pull-up resistors and voltage!!!
I can directly attach my adapter to the Pi because:
  1. the E²PROM supports input voltages from 1.7V up to 5.5V (depending on I²C frequency)
  2. every Raspberry Pi from Model B+ on has internal pull-up resistors to 3.3V
Therefore I can operate at 3.3V which is the voltage level the I²C lines are already pulled up to internally.
For use with different microcontrollers or E²PROM use level shifters.
