Python ESP8266 Pin arrangements
A project log for MakePython
Python development board based on ESP8266/ESP32/nRF52840, etc., for Python Development and Projects
MakerfabsMakerfabs 12/11/2019 at 03:160 Comments
Actually the ESP8266 pins that can be used by end users is not so much. There the SPI/I2C/UART, and few pins could be used.  The IO0 can be also used as a normaly IO port, the MCU detect IO0 state to enter the programming/working state. there some projects needs another software UART to communicating with other module such as a GPS module (the default one need to connect the PC for debugging info), as there on-board OLED,  this situation could be easier...
Schematic Released with eagle...
