- I will build the Backend for you. Options to integrate APIs into the screen right now are:
Google calendar - Timetree (shared calendar) - Weather (darksky API) - In case you don't have a 3D printer. I will print it a 400*300 4.2 Case for you and cover up to 5€ from the shipping costs
What you need to build this in your side:
Look at the components for more information. All components excluding the 3.7 Lion battery cost around 35 u$ or 40 top if you want a very low sleep consumption ESP32. But you can use any ESP32 that you already have, the essential part that is the EInk costs 26u$ in Aliexpress. Make sure to select it with Adapter Board that is the SPI adapter.
The result after building is like this, a small dynamic Eink, that you can stick to your fridge or without magnets and 2 holes, to mount on the wall.
Backend integrations are coming soon in a new format, with a small Admin-Backend so you can select what to print in your screen, plan looks like the following.
If you like the idea, just send me a short message, here or add me to your twitter and I will add you back. Please note that we are also offering to print T5S board housings for free if you register in CALE.es
CALE project has been sponsored by makers store digitspace.com
