Block Commutation
A project log for DIY Field-Oriented Control ESC
In this project I make my own brushless motor controller to implement several commutation strategies all the way to field-oriented control.
maakbaasMaakbaas 04/09/2022 at 12:030 Comments
My BLDC controller can use different control strategies to drive a brushless motor. The simplest method is called block, trapezoidal or six-step commutation, whereas the more advanced method is called field-oriented control. The board also gives you the option to use position sensing based on either hall sensors or an encoder. In this post I will first present a block commutation method. Since the motor I had available did not have hall sensors, I have first developed a sensorless approach using back EMF sensing.
Full log (Maakbaas.com)
