Implementing PIX565 a protocol that reduces UDP payload
A project log for udpx
udpx is is a technology to transport data over WiFi to microcontrollers, supporting decompression
martin-fasaniMartin Fasani 01/15/2020 at 11:300 Comments
Just for a quick resume check this tweet:
https://twitter.com/martinfasani/status/1217360074567491584
Modified slightly udpx pixels library to add a new header byte:
byte[0]protocol[80,82]P (888)R is 565
byte[1]non used0
byte[2]chunk LSB 16 bit LSB
byte[3]chunk MSB
byte[4]Length of payload LSB 16 bit LSB
byte[5]Length of payload MSB
https://github.com/martinberlin/pixels
First byte[0] is very important since identifies protocol type
P 0x50 is Pixels, a byte per color. So it takes 3000 bytes to feed a 1000 pixels RGB Led matrix
R 0x52 is 565, using 5 bits for Red, 6 for Green and 5 for Blue. So it reduces the color brightness gradients in 31 for R/B and 63 for Green. But it also resuces in 1/3 the udpx payload, using only 2000 bytes to feed every pixel of a 1000 RGB Matrix.
That makes everything faster since it's also ZLIB compressed in the App and decompressed in the ESP32 using miniz library.
Proof-of-concept videos
udpx Android application last releases
