Components, Bill of Materials
A project log for The Muffsy BSTRD - Valve Preamp
An open source Class-A valve preamplifier and regulated PSU, complete with Eagle project files and detailed Bill of Materials
skrodahl 12/01/2016 at 08:480 Comments
Here's the bill of materials for both the BSTRD Tube Pre and the Power Supply.
It contains part numbers from Mouser, and other sources where Mouser can't provide the parts. It's recommended that you buy more than the specified component quantities, especially for cheaper parts like resistors.
These are just suggestions, there are a lot of cheaper, more expensive, better, worse and higher or lower quality components available. There are also a lot of other places to get components, like http://elfadistrelec.com, http://digikey.com, http://tme.eu to mention a few.
Mouser Shopping Cart
All components below except LED resistor, transformers, tube sockets and tubes have been placed in this Mouser shopping cart: https://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=49c9a64471
The BSTRD Tube Pre:
Quantity Component Value Mouser Part #, or other source
2 Resistor, 0.6W 1k ohms 603-MF0207FTE52-1K
2 Resistor, 0.6W 22k ohms 603-MF0207FTE52-22K
2 Resistor, 1/4W 100k ohms 603-MFR-25FRF52100K
2 Resistor, 1/4W 330k ohms 603-MFR-25FBF52-330K
2 Resistor, 1/4W 1M ohms 603-MFR-25FBF52-1M
2 Electrolytic capacitors, 25V (≤10mm width, 5mm pin spacing) 47 uF 647-UKZ1E470MPM
2 Film capacitors (7.5mm pin spacing), ≥ 100V 1 uF 505-MKS41.0/100/10
2 Ceramic capacitors 0.1 uF 80-C320C104K1R
1 Stereo Potentiometer, logarithmic, 16 mm 100k ohms 652-PDB182-K430K104A
2 Sockets, for tube 8 pins Search for "octal socket pcb" on eBay, Amazon etc.
2 Tubes, valves 6J5 or equivalent Available from various sources, such as eBay and other online stores.
3 Screw terminals 3 ports 651-1705469
Alternative tubes that can be used with this preamp are:
The BSTRD Power Supply:
10 Diode 1N4004 512-1N4004
1 Resistor, 2W 180 or 200 ohms 71-CPF2200R00FKE14
1 Resistor, 1/4W 100 ohms 603-MFR-25FRF52100R
1 Resistor, 1/4W 820 ohms 603-MFR-25FTE52-820R
1 Resistor, 1/4W 3k3 ohms 603-MFR-25FRF52-3K3
1 Resistor, 1/4W 6k2 ohms 603-MFR-25FRF52-6K2
1 Resistor, 1/4W Suitable for LED @6.3V Calculate here
4 Electrolytic capacitor, 100V (≤13mm width, 5mm pin spacing) 390 uF 661-EKZN101E391MK35S
1 Electrolytic capacitor, 100V (≤13mm width, 5mm pin spacing) 47 uF 647-UHE2A470MPD
1 Electrolytic capacitor, 160V (≤18mm width, 7.5mm pin spacing) 470 uF 647-UVK2C471MHD
4 Electrolytic capacitor, 25V (≤13mm width, 5mm pin spacing) 3300 to 3900 uF 661-EKYB250E392MK40S
1 Electrolytic capacitor, 16V (≤5mm with, 2.5mm pin spacing) 47 uF 667-ECA-1CM470I
4 Ceramic capacitor 0.1 uF 80-C320C104K1R
1 Voltage regulator, TO-220 TL783 595-TL783CKCSE3
1 Voltage regulator, TO-220 LT1086 (or LM317) 512-LM317T
2 Heat sink SK104 567-637-20ABPE
2 Heat sink mounting kit TO-220 532-4880SG
3 Screw terminal, 5 or 5.08 mm pin spacing 2 ports 651-1711725
1 Screw terminal, 5 or 5.08 mm pin spacing 3 ports 651-1705469
1 Transformer, ≥ 15VA 9 V AC (or up to 12V)
1 Transformer, ≥ 10VA 18 V AC (or up to 24V)
Transformer options are not given, as there is too many choices depending on input voltage and designs.
