Limb Volume Estimation using a Low-Cost Repeatable Scanner Apparatus
A project log for 3D Scanner Arm Control Board
Development of a rotary scanning arm control system
walker-arceWalker Arce 01/19/2020 at 00:320 Comments
Volumetric comparison of scans obtained at varied speeds (2, 4, 6, 8, 10, 20, 30, 40 and 50 RPM) at a fixed distance revealed consistency in the quality and relative accuracy of the produced meshes. In general, no measure differed from the mean volume (434.16 ± 19.61 cm3) by more than 6.13%, which occurred only at the highest speed of 50 RPM. This indicates that the apparatus is both repeatable and accurate in its model creation.
RPM
Volume
% Difference
2
456.46
5.135548066
4
441.32
1.648381178
6
452.27
4.170473478
8
424.22
-2.290228716
10
405.81
-6.530568373
20
431.83
-0.537432149
30
414.16
-4.607329039
40
420.62
-3.119409746
50
460.78
6.130565302
