IT WORKS!
A project log for The 6502 Companion
The 6502 Companion is intended to be a development / learning environment for the 6502 microprocessor.
josh-kittleJosh Kittle 03/14/2020 at 02:230 Comments
I'll provide some more details later, but let me give you the short version - I assembled the through-hole parts on the boards from china (all the SMD work I had done)... and i fixed all of the upside-down LEDs... and IT WORKS.  The board works!  #HelloWorld!
