One of the scales arrived broken, so it is useful to use for checking fit without worrying too much about cleaning.
Mounting the scale should be straightforward now. I need a 2mm spacer between the table and the scale, and a cover. This could all be the same thing. I'll also need transfer punches and the appropriate tap drills and taps.
![](https://cdn.hackaday.io/images/1865501583633141152.jpg)
![](https://cdn.hackaday.io/images/4405961583633141417.jpg)
![](https://cdn.hackaday.io/images/6069111583633141486.jpg)
