RV-50C buying
A project log for Open Source Cinema Robot
Open Source Cinema Robot (OSCR) for everyone
no-jae-gunNo jae gun 06/20/2020 at 18:540 Comments
Why hasn't it been uploaded? I pressed the upload button..
anyway
I bought an RV gear that would fit the bottom of the robot at a local bearing store.
at around 890$ (50%~ off) (because i m student)
Normaly the color of the outer case is not black, but this is. because it's not a standard product.
As you can see from the drawing, the shape of the Center gear is different.
Of course, i will planning to produce and upload hardware for the basic model later.
So.. i have to do make another center gear fitted in this gear.
this gears reduction ratio is 1:49.82(normaly. you can manage this ratio using custom gearbox)
