3D Printed "Transformer" Styled Mechanism 2
An electro-mechanical rolling / walking / rolling mechanism.
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
https://youtu.be/BcPwsTvQI7g
I finally found some time to return to the "transformer" styled mechanism. This is version 3 which is the first rolling / walking / rolling mechanism.
To roll, I added the wheels, tires (33mm ID, 3.5mm section, o-rings) and axles.
The mechanism is propelled by an N20 30rpm 6vdc gear motor, powered by a 3.7vdc 100ma LiPo battery, and uses a compression spring (32mm length, .5mm section, 8mm OD) in the transmission mechanism. The remaining 24 (unique) components are entirely 3D printed.
