Simple Monster Position using IR Sensors
A project log for Duel Disk System ®
Device to play card games using a Virtual Field via NFC tags on the card sleeves and sensors to detect positions.
augustoAugusto 04/01/2020 at 21:380 Comments
I wanted to show you some basic field Monster position detection, for it I built a simple prototype using IR sensors. The code for detection can be found named "MonsterZoneDetection_IR". As you can see a transparent sheet serves as a place for the card to lay down and since IR light passes through this sheet it does not get detected as a card. When a card is placed on top of a sensor it gets triggered and outputs a digital high signal.
