Prettifying and test fitting
A project log for Tambourine Clamp
A clamp for mounting a tambourine to a drum kit
koen-van-vlietKoen van Vliet 02/24/2020 at 16:350 Comments
I printed the clamp out of black PETG. This looks a lot nicer than my initial blue PLA prototype. It should also be a fair bit stronger. I placed a black norprene tube around the rim of the tambourine to dampen the impact of the drumsticks a bit.
The norprene tubing is 10mm outer diameter, 1.7 mm wall thickness.
