Add ACIA (Serial) Port
A project log for MIKBUG on Multicomp
MIKBUG Running on Multicomp with 6800 CPU
land-boardscomland-boards.com 03/04/2020 at 15:390 Comments
There is currently an ACIA emulator which uses the ANSI Display and PS/2 keyboard connection. Adding a second ACIA port which will use I/O pins as a serial port. An FTDI can be attached to these pins which will allow access from a Computer USB port. This is easier for screen capture and uploading of S-Record files.
Using Neal Crook's "Buffered UART" VHDL code which has improvements compared with Grant's ACIA code but it has a small difference since it uses Serial Clock Enables.
Locating the new serial port at addresses $8028-$8029.
Adding a serial port select jumper using one of the J3 jumper blocks on the RETRO-EP4CE15 card. If the jumper is left out the VDU and PS/2 are used for I/O. If the jumper is installed the new serial port is used for I/O. This is done by swapping the memory decode addresses.
Tested and works.
