Maxed Out SRAM
A project log for MIKBUG on Multicomp
MIKBUG Running on Multicomp with 6800 CPU
land-boardscomland-boards.com 06/26/2020 at 13:490 Comments
Couldn't resist tweeking the 6800/MIKBUG files. Opened up a window of the ROM from 0xFC00-0xFCFF and relocated the I/O up to that range. Had to do more mods to the MIKBUG source file.
Now MIKBUG has a phenomenal 60KB of SRAM.
Notes when altering MIKBUG source code
Need to set the start of the 128 bytes scratchpad SRAM
VAR EQU $EF00 ; TOP OF USER MEMORY
Need to set the I/O addresses
ACIACS    EQU    $FC18        ;V1 has $8000, $8001
ACIADA    EQU    $FC19
PIAD1A    EQU    $FC00        ;V2 has PIA support
PIAS1A    EQU    $FC01
PIAD1B    EQU    $FC02
PIAS1B    EQU    $FC03
PIAD2A    EQU    $FC08
PIAS2A    EQU    $FC09
PIAD2B    EQU    $FC0A
PIAS2B EQU $FC0B
Need to set the start of the code
;    OPT    MEMORY
    ORG    $F000            ;V1 has $F800H
