FigFORTH Running
A project log for MIKBUG on Multicomp
MIKBUG Running on Multicomp with 6800 CPU
land-boardscomland-boards.com 04/26/2022 at 19:220 Comments
Ported figFORTH to the card. It runs. Banner is Forth-68.
Running
Type J 0100 to run.
Sources
Required a bit of tweeking the assembly code so that it would assemble using A68.
Ported Source is here.
Original Source is here.
