I designed an electronics mounting panel for the cnc candle carver this week. It includes the 24 VDC power supply, a motor speed controller, three stepper motor drivers, a power switch, and a Aruduino Uno with grbl. The bottom and side panels are to be laser cut out of 1/8in baltic birch.
Turns out a commercially available CAM software called DeskProto has the capabilities to generate the rotary machining tool path instructions needed to operate the cnc candle carver machine. I will put the custom software on the hold now while I learn the parameters that the DeskProto software uses to generate the tool paths. The video below explains how to use the software to generate tool paths for complex geometries.
John Opsahl
That "commercially available software that does the thing I wanted and it's already optimized" is always nice to find, and also super annoying, because why did I spend 6 weeks making it myself?
