Rope making can use a simple machine to twist individual yarns into a rope.
Options for making a rugged machine:
CNC aluminum or steel
Pros:
   Strong
Cons:
   Complicated assembly to accommodate standard bearings.  Have to create separate piece for hook (and bolt/nut) so that bearing can be installed.
    Need access to CNC
Bent steel
Pros:
  Strong
  Single piece of metal, no connectors required.
  Install bearings on rods and then bend to shape.
Cons:
  Need tool for bending steel rod
3D printed plastic
Pros:
   Tools available to fabricate
Cons:
   Poor strength, especially when operated by children.
   As with the CNC option, one must print in multiple pieces for hook (and bolt/nut) so that bearing can be installed.
